Getting redirected to example.com after successful login
After successfully logging in on community.bloom.pm the user is redirected to example.com
The DISCOURSE_HOST env is properly configured, what’s the issue here?
your discourse hostname is not correctly set
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: < your url >
correct that and then rebuild your app.
Did you run discourse-setup and/or follow How to install Discourse in production? (Because if you did, I don’t think you could have this problem.)
