Give a group moderator access
We have a group for our team members, which is not the default staff one, that we’d like to also have mod access by default. Is it possible to have that group automatically given mod level access?
Currently it’s a manual process, but that’s become unwieldy due to numbers.
(Side note, if this would be easier if we just used the default staff group then that’s fine!)
Tricky problem, we require some extra security for staff which is why you need the extra manual step. At the moment the only way I can think of achieving this behavior is with a custom plugin or script you would run against our API daily, I wonder if sso is the best path here, I think you can specify moderator in the sso payload
