Glitch in white/grey separation when updating Latest with new topics
(Erlend Sogge Heggen) #1
Don’t know exactly how to reproduce yet, but I think it happened when I updated the topics list two times in a row.
Here it is after 2nd update:
Still present after 3rd update:
Also notice the pinned topic is being pushed down. Should that be happening? (come to think of it, why haven’t I gotten to dismiss that sticky yet?)
Notification when a moderator or admin deletes your message
(Sam Saffron) #2
This is a known issue was reported elsewhere, but I am not convinced what we are doing now is wrong.
Regarding striping, we will fix this when we upgrade htmlbars cause our DOM will be free of a ton of metamorphs which make this much simpler to style.
(Erlend Sogge Heggen) #3
Goody good good. Good.
(Jeff Atwood) #4
(Bill Ayakatubby) #5
Ah, the elusive htmlbars. Like its cousin the unicorn, rarely seen outside of enchanted forests and magical glades.
(lid) #6
There are 2 related bugs Here.
##bug 1 - .highlighted class is overridden by tr.nth-child rule
  1. I don’t see the blue highlight when topics are added ( should probably be reported as new bug/topic )
    This most likely because this rule take precedent over the .highlighted class
.topic-list>tbody>tr:nth-child(even){
###solution 1
add !important to .highlighted css class
##Bug 2 - highlight functionality hard-code the background-color creates mess odd/even striping
This is actually what the original author is talking about.
###Solution 1
remove the hard-coded background-color from the element style attribute,
.animate({ backgroundColor: originalCol }, 2500, 'swing', function(){
        $topic.removeClass('highlighted');
        $topic.css('background-color',"");  //Remove hardcoded background
discourse/topic-list-item.js.es6 at bad5938cddbda1e1dc81ae97ca03e9907776eb10 · discourse/discourse · GitHub
When we remove the background-color nth-child rule to do it job, and stripping will be fixed.
Rule reference:
.topic-list>tbody>tr:nth-child(odd|even) { ... }
##solution 2 - dirty fix
Run this code to reset the background color using javascript after items added and highlight finished
This concept could also be adopted to $.addClass instead with class that has background-color !important
$("tr.topic-list-item").filter(":odd").css("background-color","#fff");
$("tr.topic-list-item").filter(":even").css("background-color","#f7f7f7");
Topic List - new items does not highlight
(Robin Ward) #7
I think this is fixed due to 1.8.1 removing metamorphs from our codebase.
(Jeff Atwood) #8
