Global notice, where do I find that
Where can i edit/create the global notices?
I can’t find that. A screenshot would help me.
(Discourse Version is 2.2.0.beta9)
Thanks Tikkel
Admin>Settings>Other
Under Admin>Settings you can also use the filter box to find what you want
Thank you!
The filter was a good idea from you.:+1:
pipe dream:
The global banner and notes system should be an extra section.
For beginners difficult to understand in the beginning.
And there should be the possibility to show more banners / notes.
Click the gear next to a topic and you can “pin” it.
