Google AdSense plugin
(ljpp) #179
I would like to re-propose this what I mentioned in February. The 320x50 mobile banner is performing very poorly and since mobile usage is at 50% and growing, this is a problem for ad-funded communities.
Another thing I keep wondering is that should responsive ad codes be used instead of fixed size?
(Karthik) #180
That’d be nice to have.
(Sebastian) #181
Well my love affair for this topic was short but sweet. Google’s policies makes Adsense for communities a very hard line to walk on. I had to decide between censoring my forums or deactivating Adsense. I opted for the latter. Now trying to figure out a way to put up Amazon CPM on my Discourse…
(Spooky) #182
I highly recommend responsive ads, all my sites are running this. Noo need to do anything and it chose the right size based on the screen size. I also think that the best thing is just to have places where we can inject HTML code, it’s a more versatle solution and you can put any ad or HTML code you want.
(Spooky) #183
Can you please tell me:
  1. What happens if the user resize the browser window to mobile size, does it change the ad size or it will remain large?
  2. Can I put an ad only in topic pages?
Thanks in advance.
(ljpp) #184
@michaeld Any chance of adding the 300x250?
#185
plugin is breaks the site with the latest updates:
(gauthier) #186
Hi,
This plugin is still no compatible with the last version of discourse?
It’s seems ok with the ‘stable’ branch.
(Michael - DiscourseHosting.com) #187
Eviltrout helped us out by creating a pull request, however we cannot get it to work, so I reverted it.
You could try to check out this commit and see it if works:
https://github.com/discoursehosting/discourse-adsense/commit/6c9cdc9382c16d0c4de5e460110ef9bab4ddcfe2
Can someone repair our plugin?
(gauthier) #188
Thanks, but it’s same problem…
(Michael - DiscourseHosting.com) #189
I’m sorry, but we’re lost. Our Ember knowledge is minimal.
I’m offering one year of free hosting on our Professional plan for whoever can fix this.
(Erlend Sogge Heggen) #190
If you’re gonna have a hard time maintaining this plugin, wouldn’t it be better to move your customers over to our officially supported AdSense plugin?
(Michael - DiscourseHosting.com) #191
Last time I checked your plugin is incompatible with ours, so the transition is not easy and we decided it is more easy to pay someone to fix it.
And:
  • I am getting a bit sad of writing plugins that suddenly break and then being told that it’s not “officially supported” and we should abandon it. (Don’t get me wrong - I appreciate @eviltrout making a PR the same day it broke - but unfortunately it still doesn’t work for us and for others)
  • Our customers do not want ADVERTISEMENT in caps above the ad
  • I think this plugin is used by more people than our customers and many people have asked us to fix it.
(Neil Lalonde) #192
Some sites require it, so it’s on by default. To disable, use the following CSS:
.google-adsense-label, .google-dfp-ad-label, .amazon-product-links-label {
  display: none;
Also, there’s a stable branch of the plugin which currently has all the fixes from master. @tgxworld merged it so I’m guessing it works against stable Discourse.
(Michael - DiscourseHosting.com) #193
The plugin was fixed by @vinothkannans ! Great job and thanks man!!
(Turned out @eviltrout’s fix caused a crash when the plugin decided not to display ads, for instance because of the max. trust level setting)
(Robin Ward) #194
That explains why I couldn’t reproduce it. I had everything set up to display ads so that I could confirm it was working!
(Mitchell Krog) #195
Thank you, works beautifully.
(Simeon) #196
Would prefer this plugin to serve ads based on Group, rather than Trust Level. Possibility of this becoming a feature?
(Michael - DiscourseHosting.com) #197
Can you give a few use case examples for that? Just want to know I’m understanding your needs correctly.
(Simeon) #198
I serve ads to users based on whether they have donated to the forum or not. When they donate, they get put into a group. I would prefer to show ads based on whether they are a member of a particular group or not. Their trust level isn’t really the issue here, it’s how big a financial contribution they’ve made to offset the needs to have ads on the site at all.
