Google Login is not showing
As you can see I enetered the app id and secret key and enabled the login but still not showing on my website.
Refer to http://forum.thecodesheet.com
Thanks
That is very weird, if that setting is enabled, then it should definitely show up. Are you using the standard installation method? Any unusual plugins?
Yes, everything is perfect
If you refresh your admin panel, is the site setting still enabled?
