CUSTOMIZE → THEMES → DEFAULT (Default is the key!) → EDIT CSS/HTML
COPY / PASTE YOUR GOOGLE SITE VERIFICATION CODE IN COMMON <HEAD>
then SAVE
START ENJOYING LIFE AGAIN!
then SAVE
Can you elaborate on Google site verification codes and where to get them?
Login into your Google Search Console
https://search.google.com/search-console/about
If you haven’t added your “Property” yet, you need to do this - then you will get the code under SETTINGS.
I have 5 properties (recommended by Google).
http://DomainName.com
https://DomainName.com
http://www.DomainName.com
https://www.DomainName.com
https://forum.DomainName.com
Not including the https://store.DomainName.com
Instead of altering the Default theme (which can be overridden through the course of updates or rebuilds) one should just create a separate theme component and add their GWT verification tag to it.
