Graceful theme - topic progress indicator anchors on top of reply button
(Stephen) #1
iOS12/Discourse App/ here on meta:
After the last post where the topic progress indicator is meant to anchor below the last post it actually sits on top of the reply button.
A graceful theme for Discourse
(Joffrey Jaffeux) #2
Safari view controller bug, can’t do much about it. We will get rid of it probably soon.
A recent css change might have made it worse though, but it has been working bad on safari view controller for a long time.
(Stephen) #3
It doesn’t occur with other themes though?
(Joffrey Jaffeux) #4
Do you have it when opening directly in safari?
(David Taylor) #5
I can repro on chrome desktop:
Maybe related to @pmusaraj’s change today: Fix progress bar position when theme has header elements outside #mai… · discourse/discourse@533315a · GitHub
(Joffrey Jaffeux) #6
Yes this is the commit I was refering when I said a recent commit might have made it worse.
(Stephen) #7
Yes occurs in Safari mobile too
Floating/Missing post count box
(Sam Saffron) #8
@pmusaraj can you investigate this issue?
(Kris) #10
On mobile I just had extra space to compensate for the additional padding for the theme on #main-outlet (so I removed that), for Desktop the positioning applied seems off? I don’t have any additional styles specific to the progress bar there.
(Penar Musaraj) #11
@awesomerobot this is caused by the margin-top property on #main-outlet. With the change I did earlier, that margin property causes the progress bar calculation to be wrong.
I made a PR for the Graceful theme, switching the margin-top on #main-outlet for padding-top on #main. Let me know if this doesn’t work.
(Kris) #12
Ah, noted. Will avoid adding margin to #main-outlet. Merged and fixed, thanks!
(Jeff Atwood) #13
