Gravatar is not working
On our test installation at DigitalOcean we seem to have some issue with the gravatar. When we try to use gravatar as the source of the avatar image, we get the following alert. Curling the corresponding gravatar URL from the server seems working fine, so there seems no network issue.
Sorry, we can't find any avatar associated with that email address. Can you try uploading it again?
Does it happen for every e-mail address, or just some? Anything special in your configuration (such as SSL, a proxy, IPv6, etc)?
  • We checked with two accounts, it fails for both.
  • We crated the droplet with IPv6 enabled, so both IPv4 and IPv6 addresses are assigned to the instance.
  • Using Let’s Encrypt for SSL, and from the admin control panel of Discourse HTTPS only is enforced.
Me too? How to fix it, i have use Cloudflare.
Thanks
I have Fixed, i find this topic in google, you can use google translate: https://forums.wbuy.pro/t/how-to-fixed-we-could-not-find-a-gravatar-in-discourse/566
