Gravatars not working after rebuild / uninitalized constant error
Avatars are not showing up after rebuilding containers
Example url:
https://community.bloom.pm/user_avatar/www.example.com/dmn/25/5_2.png
I checked the db the data is valid
id | user_id | custom_upload_id | gravatar_upload_id | last_gravatar_download_attempt |         created_at         |         updated_at
  4 |       2 |                5 |                    | 2018-04-04 09:14:47.001205     | 2018-04-04 09:14:42.021223 | 2018-04-04 09:16:09.296377
(1 row)
 id | user_id | original_filename | filesize | width | height |                                    url                                    |         created_at         |         updated_at         |                   sha1                   | origin | retain_hours | extension | thumbnail_width | thumbnail_height | etag | secure | access_control_post_id | original_sha1 | animated | verification_status | security_last_changed_at | security_last_changed_reason
  5 |       2 | DMN-pic.PNG       |   166259 |       |        | /uploads/default/original/1X/234dc08d7abf51126296472362d5dca6731d54df.PNG | 2018-04-04 09:16:03.160224 | 2018-04-04 09:16:03.165854 | 234dc08d7abf51126296472362d5dca6731d54df |        |              | PNG       |                 |                  |      | f      |                        |               |          |                   1 |                          |
(1 row)
And the file exists on the server
root@d705352cbe86:/var/www/discourse# ls -ail  uploads/default/original/1X/234dc08d7abf51126296472362d5dca6731d54df.PNG
787463 -rwxr-xr-x 1 discourse www-data 166259 Apr  4  2018 uploads/default/original/1X/234dc08d7abf51126296472362d5dca6731d54df.PNG
What could be the problem here ?
I launched rails console and added some debugging lines and ended up seeing InvalidAccess error on uninitialized constant
Did you define your hostname in your app.yml? How did you install Discourse?
this issue is related to
https://meta.discourse.org/t/getting-redirected-to-example-com-after-successful-login/203720/4
