Heart (like) button disappears after clicking
(Erlend Sogge Heggen) #1
Continuing the discussion from UI Bug with “Reply as new Topic” button:
Here’s what I’m seeing right after clicking the heart icon or the “Like it too”:
Possibly another bug related to the Font Awesome upgrade?
Put likes and replies in the bar, not between the posts
(Brentley Jones) #2
No, I think it was that way before. Unlike it and the heart comes back. It might be intentional.
(Erlend Sogge Heggen) #3
I thought that might be the case. If it is, I don’t like it one bit. It’s highly inconsistent. Bookmark turns red (edit: changes color). Flag turns red. Heart disappears-- say what?
(Jeff Atwood) #4
Bookmark turns blue.
Red means something else.
(Erlend Sogge Heggen) #5
Oh right. Still doesn’t make the disappearing heart any less confusing though. It didn’t use to be like this. What was the reasoning behind the change?
(Jeff Atwood) #6
It was always like that for as long as I’ve been on the project. Not sure what you’re thinking of.
(Erlend Sogge Heggen) #7
Really? I seem to recall it used to turn the heart soft red after clicking it, but maybe that’s just wishful thinking. I’ll rephrase then:
What is the reasoning behind this behavior?
Personally I find it very disruptive to click a button and have it disappear on me.
(Dave McClure) #8
Always been like that - always been a little odd - never been a priority.
This was previously discussed in this thread…
I looked at the code briefly and got lost pretty quickly… likes and bookmarks are handled pretty differently under the surface.
(J Phani Mahesh) #9
The like button is like a Touch-me-not. Easily offended, and runs away if you poke. Poor thing!
(Erlend Sogge Heggen) #10
If the strong red was the problem then maybe you guys should have played with the coloring more before deciding to turn it invisible upon click. Just a more dimmed out red would have gone a long way I think.
FontAwesome also has empty hearts and flags, why not just use those, like you’re already doing with bookmarks?
Let Leaders (trust level 3) edit older posts
(Jeff Atwood) #11
Heart button now stays around after tapping, and changes color per @mcwumbly’s idea to indicate more strongly what YOU liked in the topic.
(Jeff Atwood) #12
