Hello Bar integration issues
(Manoel Lemos) #1
Gents, I’m using an very interesting tool to drive traffic across the different destinations of my community. One destination is the discussion forum running Discourse and other is the blog running WordPress.
This tool is called Hello Bar and it is basically a bar that stays in the top of the site and links to other places or can be used to collect emails or social networks followers. It worked fine when I added the bar to my Wordpress Blog, but it failed (a bit) when added to my Discourse forum.
You can check the two situations here:
The error is that the Discourse page was suposed to be pushed down by the Hello Bar, but it isn’t being fully pushed down. Then the layout is broken.
Can anyone help me with this?
(Jeff Atwood) #2
Did you try contacting Hello Bar support?
(Manoel Lemos) #3
Yep, just sent them an email and I’m waiting.
(Manoel Lemos) #4
Ops… I just found the error.
I was including the code snipet in the begin of the page and not the end.
Changed to use Page Footer and it just worked fine.
How do I solve this issue here?
(Jeff Atwood) #5
