Help API error when update from 2.1.0.beta4 to 2.1.0.beta5
(Hình Sỹ Mô) #1
I update from 2.1.0.beta4 to 2.1.0.beta5
error: The underlying connection was closed: An unexpected error occurred on a send.
Help me !
(Sam Saffron) #2
Try upgrading from the console:
cd /var/discourse
./launcher rebuild app
(Hình Sỹ Mô) #3
Thank ! I try upgrading from the console but is not ok
(Sam Saffron) #4
You are going to need to post the errors from the upgrade logs, also try running discourse doctor, maybe you are out of space
(Jared Needell) #5
Anyone find a fix for this? I usually upgrade every 6 months and I noticed all my API integrations are broken. If I run an API call from a browser there’s a response but the same thing in a curl or Invoke-WebRequest I got Invoke-WebRequest : The underlying connection was closed: An unexpected error occurred on a send.
(Blake Erickson) #6
Can you give an example api request that is not working?
