Help cant login
(Adam Hockley) #1
please can tell me why cant login to my forum,
Adam
(Rafael dos Santos Silva) #2
You disabled all login methods, login using https://community.preecard.com/u/admin-login and enable at least one.
Should we check if at least one is enabled @team? There is a lot tough, between local, social, sso and plugins.
(Robin Ward) #3
It might be annoying if we validated it on save, because you might want to remove some before adding a plugin or something. In the case where there are no login providers present by the time the user visits the site, we could display an error message there rather than just no buttons. I do think that would be an improvement.
(Adam Hockley) #4
thanks now been resolved
