Help! Email issues after 1st digital ocean bootup. Curl test worked with email. Pasted password
(Dylan Hunt) #1
Help :confused: digital ocean tier 3 (40gb ssd 2gb ram).
I tried this TWICE and still the same result. What am I doing wrong? I am using Sparkpost.
(Jeff Atwood) #2
Follow the email troubleshooting topic in #howto
(Dylan Hunt) #3
Already done โ€“ CURL test works fine - got the test email from sparkpost.
I copy+pasted the same password for curl test.
Here is my setup, which seems great (password filtered):
Used a standard 1-click digital ocean setup โ€ฆ
I never received my admin email after registering with that email.
(cpradio) #4
And you followed this?
(Dylan Hunt) #5
Yes โ€“ See the screenshot above, itโ€™ll be matching the guide. I tried the password twice. Curl test worked using the same info. Send via SMTP is checked.
Are there specific logs I can check regarding smtp to further diagnose (will Google while waiting for a response, too)?
EDIT: AHH! It works! I reset using /var/discourse/launcher rebuild app
