Help! i can't find app.yml
Hi! i’m running Discourse Bitnami Stack on my Ubuntu server.
but i did not setup the mail settings correctly.
Can some body tell me where to find the app.yml to fix this?
Thank You.
Ask Bitnami. They probably know where they put it.
If you want help here, though, you’ll need to follow discourse/INSTALL-cloud.md at master · discourse/discourse · GitHub. And then app.yml will be right where everything here says that it is.
Ok. Thank you.i will go ask bitnami.
