Help needed - A plugin code causing discourse instance crash
(Rahul) #1
I have written a plugin which display latest 5 topics as per the category of topic on topic pages for web spiders but after sometime my discourse instance automatically gets crash and website got down then I have to restart the docker then again it will run for sometime and crash again randomly and there is no error related to my plugin in error logs
I would really thankful if somebody can point out how can I fix this problem, here is my code snipped:
I have created a plugin file under:
/plugins/show-latest-links/app/views/connectors/topic_header/latest_category_topics.html.erb
My Code Snipped:
(Rahul) #2
@techAPJ could you please suggest why the system is crashing by using above code? Thanks
(Erick Guan) #3
I believe you can find error logs under the shared folder. It seems a file called production.error.log or production.log
(Rahul) #4
I am looking for error at http://discourse.mydomain.com/logs but it does not show any error related to my plugin, the website just gets randomly crash and webpage returns 504 error
(Erick Guan) #5
Nah. You have to go to /var/discourse/shared to look for the actual log file. If the site is broken, it can still generate right log meesages.
(Rahul) #7
@fantasticfears production_errors.log is blank and production.log does not contain any errored log related to my plugin, in all the log entries it is showing Completed 200 OK
(Erick Guan) #8
What about unicorn.log?
(Rahul) #9
unicorn also does not have any error related to my plugin :frowning:
(Rahul) #10
I have added these lines on top of my code:
require 'open-uri’
require ‘net/http’
Now system is not getting down after every 20mins but it is still getting down after 24-30 hrs
Is there any other way I can fetch category wise list of questions apart from what I have used by calling a rest API?
