Help with adding script tag to a plugin
plugins
#1
I tried whitelisting simple html tag via plugin - It worked fine.
(function () { Discourse.Markdown.whiteListTag('textarea'); })();
Then tried adding asciinema script as mentioned here
Discourse.Markdown.whiteListTag('script', 'type', 'text/javascript');
Discourse.Markdown.whiteListTag('script', 'src', /https:\/\/asciinema.org\/a\/\d+.js/);
Discourse.Markdown.whiteListTag('script', 'async');
but I’m unable to whitelist the script tag. I would like to embed bellow on discourse.
<script type="text/javascript" src="https://asciinema.org/a/3uj8c8f04q9434ffsvk4s2sbb.js" id="asciicast-3uj8c8f04q9434ffsvk4s2sbb" async></script>
I’m really stuck here…awaiting for responses/help on how to achieve this. thanks
(cpradio) #2
You may want to look at how the Google Adsense plugin works
Or the lazyYT plugin (this may be more helpful)
#3
Thanks for the links. Looking into LazyYT implementation. :grinning:
(Ismael Olea) #4
Did you finally got an asciinema integration with Discourse?
