Help with banner
#1
Hi guys, i could use some help…
im having a problem to put a banner on the same position as logo or menu, to fill that white space.
any advice?
(Vinoth Kannan) #2
Did you tried above plugin? I guess this plugin will display the ad below menu bar. But it still better option for your need.
#3
i tried but no luck…
i really cannot figure out this :confused:
