Help with using CURL and API for Create Users
(Jared Needell) #1
I’m trying to use curl and the api to import a user and it doesn’t seem to be working. Can you see what I am doing wrong?
(Kane York) #2
You need to put quotes in the URL, the bash shell is interpreting the &s as a command separator.
(Jared Needell) #3
I just did that and I don’t get any response.
I’m also trying it with chrome’s advanced rest api and it says no response and a 500 internal server error
(Kārlis Gaņģis) #4
I had the same issue - user create API returning empty response and 500 internal server error.
Finally discovered the cause - we are using SSO and local users were disabled. I checked “Enable local username and password login based accounts. (Note: this must be enabled for invites to work)” under Settings/Login and the API started to work.
(Jared Needell) #5
@riking @sam
Can this get fixed to allow Create users even if local user/password is turned off?
(Jared Needell) #6
Just wanted to confirm, the create users endpoint does work when I enable Local Logins. When I disable that, it doesn’t work. I’d like the users to use their Google Apps SSO that I have configured but not have to register on their first login.
Thanks @Knagis on that find!
(Jared Needell) #7
Any updates on this?
