High dockers CPU usage
I suspect I’m experiencing the same issue as Docker using a lot of CPU. I’m sorry, but Discourse and docker are black boxes to me.
While docker is using almost all my server’s CPU my site is still up.
I began the process of trying to downgrade docker, as suggested in the link above, but I fell at the first hurdle. The docker rm -f app command failed with this error:
root@discourse-2gb-nyc3-01:~# docker rm -f app
Error response from daemon: Could not kill running container 8bba540a7daa9d35c1091824856d4ff017fc5df8b97f0247b5e0f00581f780df, cannot remove - Cannot kill container 8bba540a7daa9d35c1091824856d4ff017fc5df8b97f0247b5e0f00581f780df: connection error: desc = "transport: dial unix /var/run/docker/containerd/docker-containerd.sock: connect: connection refused": unknown
Docker version:
root@discourse-2gb-nyc3-01:~# docker version
Client:
 Version:      17.11.0-ce
 API version:  1.34
 Go version:   go1.8.3
 Git commit:   1caf76c
 Built:        Mon Nov 20 18:36:37 2017
 OS/Arch:      linux/amd64
Server:
 Version:      17.11.0-ce
 API version:  1.34 (minimum version 1.12)
 Go version:   go1.8.3
 Git commit:   1caf76c
 Built:        Mon Nov 20 18:35:10 2017
 Experimental: false
Docker info:
root@discourse-2gb-nyc3-01:~# docker info
Containers: 1
 Running: 1
 Paused: 0
 Stopped: 0
Images: 3
Server Version: 17.11.0-ce
Storage Driver: aufs
 Root Dir: /var/lib/docker/aufs
 Backing Filesystem: extfs
 Dirs: 15
 Dirperm1 Supported: false
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
 Volume: local
 Network: bridge host macvlan null overlay
 Log: awslogs fluentd gcplogs gelf journald json-file logentries splunk syslog
Swarm: inactive
Runtimes: runc
Default Runtime: runc
Init Binary: docker-init
containerd version: N/A (expected: 992280e8e265f491f7a624ab82f3e238be086e49)
runc version: 0351df1c5a66838d0c392b4ac4cf9450de844e2d
init version: 949e6fa
Security Options:
 apparmor
Kernel Version: 3.13.0-77-generic
Operating System: Ubuntu 14.04.4 LTS
OSType: linux
Architecture: x86_64
CPUs: 2
Total Memory: 1.955GiB
Docker Root Dir: /var/lib/docker
Debug Mode (client): false
Debug Mode (server): false
Registry: https://index.docker.io/v1/
Experimental: false
Insecure Registries:
 127.0.0.0/8
Live Restore Enabled: false
And here’s the system’s CPU usage for the last 24 hours:
I don’t know if it applies to your issue or if you have already tried it. But I have found that often I need to prepend commands with “sudo”. Sometimes I’ll see “permission” in the read out that clues me in, but other times not.
Try changing to the stable docker stream, uninstalling docker, reinstalling, rebuilding discourse
Okay. Is there a post that describes how do what you describe?
