`high_voltage` integration
plugins
(Hauleth) #1
I’m trying to add static pages integration to some Discourse apps. For now I’ve started writing plugin that will integrate high_voltage gem into that instances. For now this is simple script that just add that gem and setup routes for it:
# name: low_voltage
# about: Static pages for Discourse
# version: 0.1
# authors: Łukasz Niemier
gem 'high_voltage', '2.3.0'
after_initialize do
  Discourse::Application.routes.append do
    get '/pages/*id' => 'high_voltage/pages#show'
I’ve also added app/views/pages/test.html file but whenever I want to display that page I get 404 error.
Am I doing something wrong or this is impossible?
Static pages plugin
(Manthan Mallikarjun) #2
To make it work try changing this like:
to
get '/pages/*id' => 'high_voltage/pages#show', id: 'test'
and rename test.html to test.html.erb. It should work.
