# 안녕하세요, 디스코스의 현재 테마가 마음에 들어요
**URL:** https://meta.discourse.org/t/hola-me-gusto-el-theme-actual-que-tiene-discourse/409101
**Category:** Support
**Created:** [8월 2, 2026, 9:42오후 UTC](https://meta.discourse.org/t/hola-me-gusto-el-theme-actual-que-tiene-discourse/409101 "2026-08-02T21:42:07Z")
**Posts on this page:** 2
**Page:** 1
<div class="post-metadata">
### Author: ![Picho\_Pelis](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/picho_pelis/32/499976_2.png) [@Picho\_Pelis](https://meta.discourse.org/u/Picho_Pelis)
#### Post date: [8월 2, 2026, 9:42오후 UTC](https://meta.discourse.org/t/hola-me-gusto-el-theme-actual-que-tiene-discourse/409101/1 "2026-08-02T21:42:07Z")
</div>
어떤 테마인지 알고 싶습니다. 감사합니다. 답변 기다리겠습니다.
### Author: ![Canapin](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/canapin/32/119591_2.png) [@Canapin](https://meta.discourse.org/u/Canapin)
#### Post date: [8월 2, 2026, 10:10오후 UTC](https://meta.discourse.org/t/hola-me-gusto-el-theme-actual-que-tiene-discourse/409101/2 "2026-08-02T22:10:41Z")
</div>
안녕하세요,
메타 브랜디드 테마에 대해 말씀하시는 거라면, 이 테마는 공개되어 있지 않습니다.
> [@메타 브랜디드 테마 홈페이지 업데이트](https://meta.discourse.org/t/updates-to-the-meta-branded-theme-homepage/401100/28?u=canapin):
> Yes, right now and at the moment are understatements here.. we won’t publicly share the Discourse brand theme. However, you can quite easily build a theme with similar blocks with [Skills for authoring themes and blocks](https://meta.discourse.org/t/skills-for-authoring-themes-and-blocks/401629).
비슷한 논의가 여기에도 있습니다:
> [@이 Meta 브랜드 테마는 특별합니다. 제 포럼에서도 사용할 수 있나요?](https://meta.discourse.org/t/this-meta-branded-theme-is-special-can-i-use-it-on-my-forum-too/407076?u=canapin):
> I wanna acknowledge & appreciate something. I really love Discourse’s Meta Branded theme. Many other forum sites look depressing/overwhelming. I find this theme very beautiful, without being flashy. Appealing as mellow, peaceful, pleasant, modest, modern, polished, sophisticated & quietly elegant. I was surprised feeling such a difference in enthusiasm; even compared to well designed forum apps. This UI literally made me like working on these pages so much more. It’s like the feeling of getting…
