Hosed my discourse install by adding jquery src link to <head> customization
(august) #1
I seemed to have hosed my install by trying to include jquery in the <head>
Now, I can’t reply to posts. I can’t even revert to a backup. It appears that all messaging is broken.
I tried to go into the docker and DELETE the style from the user_customization table, but that didn’t help any.
Is there anything I can do besides re-install everything?
Thanks -august.
(Jeff Atwood) #2
You will need to remove the customization via the command line. I believe there is something in the howto category on this.
(Robin Ward) #3
Also we include jQuery in Discourse already, you shouldn’t need to add it if you want to use it.
(august) #4
Google isn’t giving me any results. Is there a command I can run to wipe out all customizations? I can’t find it in any docs.
(Steven Greco) #5
I think this is what you are looking for. I have done something similar in the past.
(Jeff Atwood) #6
Odd I found it first try…
(august) #7
Thanks everyone. I was able to restart it without the customizations.
I’m curious though how this would break all messaging. I’m evaluating discourse for my company and this seems very fragile.
Re: googling…it always helps if you know what to look for. I do hope the paid for support is less snarky.
(Jeff Atwood) #8
We definitely like people who pay us money more! :wink:
(Kane York) #9
Hmm, should we reject any customizations that contain the word “jquery.min” in order to avoid this? Put up a message saying something like:
It looks like you’re trying to import jQuery. It’s already there! Plus, you’re going to need to change the way you write stuff to deal with the dynamic updates. See here.
