Host/Ubuntu restart?
(Alexandra) #1
Beginner’s question:
I just ssh-ed into my virtual Ubuntu server at Digital Ocean to download the latest Ubuntu updates using
apt-get update && apt-get dist-upgrade
and it says there’s a system restart required:
Welcome to Ubuntu 14.04.4 LTS (GNU/Linux 3.13.0-71-generic x86_64)
System information as of Thu Sep  8 09:23:53 EDT 2016
  System load:  0.09               Processes:              110
  Usage of /:   41.4% of 29.40GB   Users logged in:        0
  Memory usage: 86%                IP address for eth0:    46.101.219.136
  Swap usage:   33%                IP address for docker0: 172.17.0.1
19 packages can be updated.
0 updates are security updates.
*** System restart required ***
Last login: Thu Sep  8 09:23:58 2016 from [HOSTNAME]
alex@community:~$
Does this mean I do a
sudo reboot
at this stage? And will everyhing come back up normal after that?
Thanks!
"Liking" a post alerts me I have few Likes left. Settings are 2400 Likes/day
(Felix Freiberger) #2
Yes, that’s the thing to do. If you followed the normal installation instructions, Discourse should boot up automatically after that :slight_smile:
(Depending on how fast your server is, nginx will serve error pages for up to a minute. Just give it some time.)
(Alexandra) #3
Thanks Felix. My system was set-up by the Discourse team so I’m pretty sure they did a standard installation.
Rebooting now and keeping my fingers crossed …
(Felix Freiberger) #4
@codinghorror certainly does that, so you should be fine :slight_smile:
(Alexandra) #5
OK, the system is back up and everythings seems to be running fine.
Thanks again Felix and you too, @codinghorror.
