How can I add a gemfile to the docker container?
import
docker
(Luke Mackenzie) #1
I’ve installed discourse on a Vagrant box using this guide:
(had to remove link as discourse was complaining I can only post two links even though I was only including two links, wtf ?)
I’d like to make use of https://github.com/initforthe/forum2discourse and the instructions are aimed someone who knows a bit more about ruby than I do (which is nothing)
I’m running discourse in the docker container on CoreOS (Vagrant on a local machine) and it is working as expected
I have a database ready to go in another container with the punBB data I want to import.
How can I -
Add forum2discourse gem to the discourse gemfile, and bundle install.
Run the relevant rake task within bundle exec
Do I need to alter a config file and rebuild the discourse container?
(Luke Mackenzie) #2
Guide used was discourse/INSTALL.md at master · discourse/discourse · GitHub
(Noushi) #3
Hi Luke,
You can access the Discourse instance by running ./launcher enter app.
There you have access to the Discourse root shell.
Hope it helps.
Cheers,
Reda
(Luke Mackenzie) #4
Thanks. Is that using nsenter as described here ?
And I would add new line gem 'forum2discourse' to the discourse Gemfile?
I’m also not sure how I would then run the rake task.
(Noushi) #5
You’re welcome.
Yes, nsenter is the underlying method.
If you want permanent changes, I would suggest you change the after_code hooks in containers/app.yml.
Your changes won’t be reverted when updating Discourse.
When you’re done editing app.yml, call ./launcher rebuild app.
(Jeff Atwood) #6
Good news, @techapj is working on a PunBB converter now.
(Luke Mackenzie) #7
Great news @codinghorror ! @techAPJ please get in touch with me - happy to test this for you as I need to import a punBB forum for a real client. Please let me know when you have some code ready.
(Luke Mackenzie) #8
Thanks again @noushi. Unfortunately, I don’t have the requisite knowledge to edit that file with the correct commands. How would I execute a command to add a gem to the Gemfile?
after_code:
    - exec:
        cd: $home/??
        cmd:
          - sed -i "\$a gem \'forum2discourse\'" Gemfile
          - bundle install
          - export F2D_CONNECTION_STRING=mysql://root@127.0.0.1:3306/database_name
          - bundle exec rake forum2discourse:import_punbb
I tried running the bundle command manually after doing ./launcher enter app and editing the gemfile but get:
You are trying to install in deployment mode after changing
your Gemfile. Run `bundle install` elsewhere and add the
updated Gemfile.lock to version control.
If this is a development machine, remove the Gemfile freeze
by running `bundle install --no-deployment`.
You have added to the Gemfile:
* forum2discourse
Is it safe to run bundle install --no-deployment ?
(Noushi) #9
You’re welcome @codecowboy .
I took a quick look at forum2discourse’s readme, I don’t think that the after_code method is the right way, plus the export F2D won’t probably do anything (if a shell is spawned for each line).
What you should do is call launcher enter app, then:
cd /tmp
git clone https://github.com/initforthe/forum2discourse
bundle exec gem build forum2discourse.gemspec
bundle exec gem install forum2discourse-0.0.0.gem
Then
F2D_CONNECTION_STRING=mysql://root@your_punbb_mysql_server:3306/your_punbb_database_name # <-- adapt this to your specific setup
Then:
(Jeff Atwood) #10
It will be in the scripts folder with all the other converters.
(Luke Mackenzie) #11
Thanks Jeff. What branch would it be in / how would I get notified when it is ready? @techAPJ
(Arpit Jalan) #12
It’s almost ready, I will ping you here personally as soon as I push it! :smile:
(Dean Taylor) #13
(Arpit Jalan) #14
Here you go @codecowboy :gift:
