How can I disable the rate limiter
(Kgish) #1
We’re suffering alot of errors (login, password reset, etc) because of some rate limit error which never goes away.
Even if the user waits a day and retries, the error persists.
Is there someway that I can disable this rate limiter?
(Jeff Atwood) #2
Which rate limit are you referring to? Can you provide more information?
(Felix Freiberger) #3
Also, is Discourse running behind a proxy or CDN?
(Rafael dos Santos Silva) #4
Responded here:
