How can I mask the ID?
When I read a post, I would like to show it by masking the writer ID.
Like this. abcdef -> abcd**
You can hide the username with CSS
Maybe try with css
.second.username>a {
    position: relative;
.second.username>a:after {
    content: '***';
    position: absolute;
    right: 0;
    background-color: #fff;
For what prupose? The CSS solutions will expose the full ID to the public, so keep that in mind. :slight_smile:
for the purpose of protecting personal information.
If by id you mean username:
This is widely used by Discourse. You can mention people with it @sungjun_hwang, use it in the search etc. Plus it’s nothing more than a username, not a real name.
There is a real name field though:
This one can be hidden from Discourse admin settings.
What is the purpose of your request? Do you want to provide anonymity for your users or something like this?
I mean username. some username is phone number so i want masking it.
Thank you. Which CSS file should I add?
Discourse makes much use of usernames and I don’t think you can make this data private.
If you hide it with css, the username will still appear in the html code and also in a lot of requests results.
In my opinion you should fix the issue at the source : why are your usernames phones numbers? :face_with_raised_eyebrow:
This is a simple example, but there are more ways. If the username is a phone number, you can use the invitation effect or click to view. Discourse Spoiler Alert
.topic-meta-data .username>a {
    position: relative;
.topic-meta-data .username>a:after {
    content: '***';
    position: absolute;
    right: 0;
It work! Thanks! :grinning:
Note that every profile path will also include the Username in the URL.
