How can I see all text contents?
#1
Please tell me how to see all text contents.
I know I can find some templates by a search function.
However, this means that without knowing specific terms, I wouldn’t be able to know what templates are in Discourse system. Given that I’d like to translate all templates into Japanese, I need to know what sentences are in Discourse system beforehand.
Thank you :slight_smile:
(Tom Wrench) #2
Admin -> Customize -> Text -> Search for the text you want to change.
Does this answer your query?
#3
Hi tomwrench.
Thank you for your help!
But I want to see all text contents in a page because I want to know how many text contents are in my web page.
Do you know how to see all?
(Erlend Sogge Heggen) #4
You’ll have to be more specific. I don’t think anyone yet understands what you’re looking for.
Can you give an example of the text content you want to see?
(Mittineague) #5
I didn’t when I first saw this the other day.
Now I think maybe a “show all” instead of a “show more” scroll loaded page, or a non-paginated page.
But that’s still only a maybe. I don’t always do so well at reading minds :sadpanda:
#6
Okay. I’ve just posted my question again! Thank you for your help!
(Mittineague) #7
Have you looked at the
../config/site_settings.yml file?
That should give you more than enough to take a look at for quite a while.
After that
../config/locales/client.ja.yml and ../config/locales/server.ja.yml will probably be what you’re most interested in.
NOTE and heed the leading comments
# encoding: utf-8
# Never edit this file. It will be overwritten when translations are pulled from Transifex.
# To work with us on translations, join this project:
# https://www.transifex.com/projects/p/discourse-org/
#8
Thank you very much :slight_smile:
I will try it!!!
#9
I have a question.
If I want change the word into more clear Japanese, do I need to sign up Transifex?
(Mittineague) #10
IMHO that would be the best way.
That way the improvements you contribute can benefit all “ja” sites.
#11
I understood it! Thank you for your kind help!!
