How can I select tags in /tags adress ? (javascript)
(SMHassanAlavi) #1
I want to select the all tags in /tags.Which selector Should I use?
I have used many class selector like:
.tag-box .discourse-tag
but none of them work properly and return wrong answer
(Felix Freiberger) #2
What do you want to select, exactly? Everything that is red in this screenshot?
If so, .discourse-tag should be enough.
(SMHassanAlavi) #3
thank you. I want this but I have used
div.tag-box
