How do add Category Sidebar?
(Hakan) #1
How can I add a separate sidebar for each category? Like Reddit, I want to add right-hand side comments or ads. I want to do this separately for each category.
How can I do it ?
(Biscuit) #2
Click the search icon (top right) and search for ‘Sidebar’
There’s a bunch of relevant topics (30+ before I stopped counting), including themes, plugins & other people asking sidebar questions. This one seems directly relevant: -
(Hakan) #3
you did not understand me.
I would like to add widget to each categorize separately
(Biscuit) #4
That is discussed in the 4th search result.
(Hakan) #5
my friend i do not want to turn it off.
You do not understand what I want.
i want:
  • Support category sidebar: Facebook Page widget vs…
  • Example category sidebar: Twitter page widget vs…
  • Game category sidebar: Steam page widget…
I can add different widgets to every sidebar I want
(Hakan) #6
Not solved my problem
(Erlend Sogge Heggen) #7
It appears you’re asking for a new feature that does not yet exist, so I moved it to #feature. See this:
(Joe Buhlig) #8
Sounds like a custom plugin would be your best bet. This doesn’t sound like something that would make it into core.
