How do I disable post auto-close?
Hello,
I’m looking for a way to disable auto-close on posts on a category (or side wide). I’m completely failing at seeing how to do this. Thanks for any help in advance.
There is no auto close by default so I am unsure what you are talking about?
I’m referring to these settings Time based auto close topics
You need to visit the category’s page (e.g. community.example.com/c/support) and then click edit. Within that menu there’s a settings tab that has an Auto-close topic hours: option. I think this is what you’re looking for?
There is, but how do i set it back to never? When i enter zero it says it has to be greater
Yeah, just delete the number and hit save :hugs:
