How do I insert javascript into the footer?
javascript
(Noah) #1
I try inserting javascript into the footer using the footer option but it doesn’t render it. What am I doing wrong?
Javascript inserted into Footer from Discourse UI not working
(Dean Taylor) #2
Make sure you have ticked the little Enabled? box:
(Noah) #3
I’ve tried that, it still doesn’t work.
(Dean Taylor) #4
In that case are you adding the code inside <script>code here</script> tags?
(Kane York) #5
Also, check your browser developer for script errors. @Noahqw
(Spooky) #6
Exactly my problem. The Javascript won’t run because it is inserted withiin a script and therefore the script won’t run because. It only works in and , but not in FOOTER or HEAD.
