How do I redirect www to non-www?
(flexihack) #1
I have read several posts on meta discourse but couldn’t find the solution. I tried to follow this post:
But it couldn’t help because it says “In this tutorial we’ll show how to redirect www.example.com and example.com to talk.example.com
right now, I’m looking for a way to redirect from www.domain.com to domain.com. Anyone can help?
When installing discourse with lets encrypt any way to have it redirect?
(Jeff Atwood) #4
You need to follow the howto you linked. It is exactly the same process, only the URLs are slightly different.
(flexihack) #5
@codinghorror I do not get this part:
path: /etc/nginx/conf.d/discourse_redirect_1.conf
    contents: |
      server {
        listen 80;
        server_name example.com;
        return 301 $scheme://talk.example.com$request_uri;
First off all, what do I change the “discourse_redirect_1.conf” to? If I want to redirect from www.domain.com to domain.com then for server_name what do I put? with or without www? Samething go to the last line. Thanks
(Arpit Jalan) #10
You do not need to change the file name, discourse_redirect_1.conf will work fine.
If you want to redirect www.domain.com to domain.com then in server_name put www.domain.com and in last line put return 301 $scheme://domain.com$request_uri;
(Tomo Vukasović) #13
This is not working for me. I tried every possible configuration…restart, rebuild and nothing. I am running docker on digital ocean. One thing that I noticed is that www was not working at all after the discourse installation, only non-www was accessible. I fixed this with CNAME, but still I can not redirect either way from non-www to www or other way around. Problem is of course with cookies I have to login separately into each version of the site.
(charles) #14
For me, I use A record for www (instead of CNAME) and reverse the configuration in this guide so my choice was going from non-www to www. Maybe this will work better for you?
(Kane York) #15
Again, don’t put a CNAME on the root domain. Two A or AAAA records to the same IP will do fine for redirecting.
For others chancing on this thread:
#16
Why shouldn’t you use CNAME for for domain?
(Michael - DiscourseHosting.com) #17
A CNAME replaces all records for the domain, not just the A record.
But a domain needs SOA, NS and MX records, and you cannot have any of those if you have a CNAME.
We don’t recommend using the naked domain for hosting anyway, it’s better to do it the other way around: redirect the domain to www.
For our hosting, we set up a generic service for that at https://www.forcewww.com/, but it’s available to be used by anyone. We automatically provision LetsEncrypt certificates so it’s usable with https as well.
