How do I use spoiler tags on my own discourse instance
(ampburner) #1
Is it a plugin? Do I need to enable a setting?
this seems to work on meta.discourse.org, but not on my own installation
(Arpit Jalan) #2
It’s a plugin, you can get it from here:
To install this plugin, refer Install a plugin section of this guide:
(ampburner) #3
Thanks!
I suppose “plugin” means I need to worry about backwards-compatability when updating Discourse?
I don’t like idea of making manual changes so I would prefer to keep my install as vanilla as possible.
This seems like a feature that should be in Discourse core. Is it on the roadmap? I can wait.
(Arpit Jalan) #4
Updates for Discourse (core) is separate from plugin updates. Plugin will be updated in case there are breaking changes, and you will be notified of update on admin/docker page:
//discourse-meta.s3-us-west-1.amazonaws.com/original/2X/2/2c1bb3582be9f689032f105f61ac09d15c370327.png
As you can see, the update notification for discourse core is separate from plugin updates (emoji, poll, docker_manager).
