How do you change permalink of a page
How may i learn to do this?
fsm
Step number 1: learn how to express your question in a clear and comprehensible way.
He wants to change /badges to /something-else
Cameron got it…just changing permalink of badges page to something else. Simple. Comprehend that, bud?
I think that the definition of permalink is likely the confusion.
Well do you want to change the url of the badges page, or do you want a permalink that redirects sums other url to the bags page? If it’s the latter, see admin /customize /permalinks.
If it’s the former, can you say what problem you’re solving?
Oh okay, I want to change the url of the badges page to /trophies.
It’ll take a plugin. Post in #marketplace if you have a budget, or see the #howto topics. I’m not sure how easy it is to override the routes, though.
You’re likely causing more problems then you’re solving.
I fear so. Messing with routing is messy business.
On the other hand the text “badge” could be easily changed to “trophies”, “awards” or whatever. Even though eagle-eyed member’s might notice the discrepancy between the URL and the title I don’t think it would be that big of a problem.
