How do you revert to previous containers?
(Ryan Erwin) #1
I saw that you can use ./launcher start app to launch the one previous container, but if I do docker image ls there are actually several discourse docker images still on my system… how do I use ./launcher to start a different instance?
I realize that I need to make sure that the database is compatible between instances.
(Jay Pfaffman) #2
will start the most recent container. If you want a different one, you can look at the run command that ./launcher spits out and substitute another image ID.
