How does "@" before User Id?
(Hakan) #1
Can we put the “@” sign in front of the user name?
example :
Ekran%20Al%C4%B1nt%C4%B1s%C4%B1
(Michael Downey) #2
You can do this with CSS customizations, using the ::before selector.
(Michael Howell) #3
https://theme-creator.discourse.org/theme/notriddle/at-username
(Hakan) #4
would you show it as an example ?
(Hakan) #5
.username a::before {
content: "@";
but there was no change
(Southpaw) #6
Hi @nothing,
I tried this on one of my themes and it worked perfectly. Did you add it to:
/admin/customize/themes/{theme_number}/common/scss/edit
Admin > Customize > Themes > [target theme] > Edit HTML/CSS > Common > CSS
(Hakan) #7
Thanks you my problem solved
