How I can get the latest inserted topic_id when I call create_topic method?
#1
You know, just like mysql, when I insert one row, I can always get the lastInsertId. I hope that when I call create_topic method, I will get the topic_id for later use. Any ideas?
(Dean Taylor) #2
Not 100% sure what API library you are using, assuming the ruby API - something like this:
post = api.create_post(topic_id, user_name, raw_post)
discourse_post_id = post["id"]
#3
I’ll give a shot! Yes, i’m using ruby api. thanks!
