How much space is required to bootstrap Discourse?
(Steve Reinert) #1
Hi,
I am trying to migrate an existing Discourse installation to Docker. This instance was installed and updated for a few months using the deprecated Ubuntu install instructions. I don’t have much space left on /var. Only 687 MB.
When the bootstrap completes, here is the last part of the output:
[167] 26 Mar 21:27:08.207 # Redis is now ready to exit, bye bye... 2014/03/26 14:27:22 Error: mkdir /var/lib/docker/aufs/diff/b0156136ca347a30a3c536a540d1074bba110e0e4a6b05620ef4528e28f71a3f/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.0.3/lib/rails/rack: no space left on device FAILED TO COMMIT 495c71a82e9a9b8e8b9e59d707ec62adae1581387fda77c75da4efcee81c7a20 Successfully bootstrapped, to startup use ./launcher start app
Here is my df -h output on /var:
Filesystem               Size  Used Avail Use% Mounted on /dev/mapper/lampsrv-var  6.0G  5.0G  687M  89% /var
The module that fails to get created or whatever varies each time. Am I correct in assuming that if I can get more space allocated to /var that this will solve my problem and I can run Discourse again? What are the bounds on the space requirements of the bootstrap process? I’ve noticed that the space it uses grows and shrinks throughout the duration.
Thanks.
(Steve Reinert) #2
The answer appears to be somewhere between 687 MB and 783 MB. I cleared about 96 MB of cached files from /var/cache and it’s running now.
(Jeff Atwood) #3
Cool so let’s call it 1 GB to be safe?
I wonder if bootstrap could check for this free disk space requirement first @sam as part of its prerequisite steps.
(Sam Saffron) #4
Should be fine to do that
(Jeff Atwood) #5
Can you add this to your list @sam? I assume it’s an easy prereq check in the bootstrapper, just make sure 1GB or more is free before doing anything involving containers.
Less support requests is a good thing.
(Jeff Atwood) #6
Did we ever add this minimum bootstrap disk space check @sam?
(Sam Saffron) #7
we have a warning I think that asks you to run cleanup
(Jeff Atwood) #8
I am quite positive that @mpalmer added a proper check in bootstrap for free space, so nobody should be surprised here. Based on other topics you will need about 5gb of space just to be safe, probably 10gb would be completely safe.
(Matt Palmer) #9
Yep, launcher gets upset if you have less than 5GB of diskspace in /var.
