How the debugging bar works? And how to hide it?
(Caue Rego) #1
You know, that little floating bar on the top-left, if you’re an admin:
What triggers it to appear? What are we supposed to do with it? And how can we make it go away?
This is probably a very newbie question, but I couldn’t find any info about it.
It does look like an awesome debugging tool if I knew what the data meant (i.e. I was actually active on github). :stuck_out_tongue:
(Gerhard Schlager) #2
That’s the MiniProfiler. @sam has written an informative blog post about it.
Of course you can disable it.
(Caue Rego) #3
Knowing the name makes the whole difference! :slight_smile:
(Jeff Atwood) #4
Just press alt+p
It is only visible to developers, which is a state above admin and moderator. It means you installed the Discourse.
