How to add a subcategory to the top nav menu?
(Tobias Eigen) #1
I know I can add a category to the top nav menu by typing category/CATNAME - that works. But how do I add a sub-category? I tried various permutations based on what I found here on meta but with no success. Most grateful for any advice.
(Daniela) #2
Ok this should work
  • go to /site.json
  • find the subcategory you want to add (in my case Private category), copy the name
  • and paste it with the suffix category/
Result:
your link will be /c/parent-category-slug/subcategory-slug
