How to align Categories in one column
(| full stack virgin) #1
My current category set-up looks like this;
but I want it to look like this.
can’t seem to find the settings for categories
(| full stack virgin) #3
so far, no edits where made/added in the backend.
but im still getting the same out put :frowning:
(cpradio) #4
Did you use the Topic Preview List plugin? If so, try uninstalling that.
(| full stack virgin) #5
ill try this one. ill get back if successful
(| full stack virgin) #6
btw, these are the plugins i have right now.
are you referring to that plugin?
not sure what to specifically remove :frowning:
(cpradio) #7
Yes, that is the one.
There are two possibilities.
  1. If you are running Docker, you will edit your app.yml file to either comment out the github clone statement for that plugin, or remove it entirely, then rebuild the app.
  2. If you are using vagrant or a development install, you simply delete the folder from the /plugins folder, and start the rails server again.
As an aside, I see that you are installing a lot of plugins without really understanding their impact to Discourse. It may be wise to slow down a bit and use Discourse without any third party plugins. As learning Discourse first, and then figuring out what is absolutely necessary for your community, would be a much simplier approach.
(| full stack virgin) #8
Thank you for the heads up…
and that worked :smiley:
thanks :smiley:
