How to assign trust levels to categories
(Micki Cockrille) #1
Hi!
I’m looking for how to assign a trust level to a category. For instance, the Lounge is automatically set up to be seen or interacted with only by trust level 3 and higher. I want to assign different levels to multiple different categories. I checked out this topic here Category allowed only for a certain trust level and the answer seemed simple, but I couldn’t figure it out.
I don’t understand where to “Give the “See” permission to the Everybody group. In fact, the howto category on Meta is set up like that” or “From the drop down, select Trust Level 3, and give them Can Create/Reply/See. So you should have two permissions, one for TL 3 and one for Everyone.” Any thoughts? Thanks in advance!
M
(Vinoth Kannan) #2
“Edit Permissions” button on category create/edit pop-up in Security tab.
(Micki Cockrille) #3
Thank you so very much for your response!!
