How to change Discourse theme?
(Edison) #1
(Joshua Rosenfeld) #2
@kudouyuzi - you’re going to need to be significantly more specific in what you’re looking for. What do you mean by “theme”? Are you looking to change the entire color scheme, just certain colors, the font, background color/image, icons, text, something else or all of the above?
(Edison) #3
Yes, I want to change all template (theme)
(Erlend Sogge Heggen) #5
Currently the recommended approach is following the same steps as this Material Theme:
But we’re working on a way to better support unique and shareable Discourse themes:
(Edison) #6
Hey sir, how do I edit About, FAQ, Terms of Service and Privacy pages?
(cpradio) #7
Try navigating to the Staff category :wink:
(Edison) #8
Thank you, I am a new user
