# How to change invite limits for everybody?
**URL:** https://meta.discourse.org/t/how-to-change-invite-limits-for-everybody/405150
**Category:** Support
**Created:** [12 juni 2026 om 10:28 UTC](https://meta.discourse.org/t/how-to-change-invite-limits-for-everybody/405150 "2026-06-12T10:28:02Z")
**Posts on this page:** 2
**Page:** 1
<div class="post-metadata">
### Author: ![Prempavee](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/prempavee/32/554302_2.png) [@Prempavee](https://meta.discourse.org/u/Prempavee)
#### Post date: [12 juni 2026 om 10:28 UTC](https://meta.discourse.org/t/how-to-change-invite-limits-for-everybody/405150/1 "2026-06-12T10:28:03Z")
</div>
hello, some of my new users receive a limit of 10 invites max and I cannot see how increase that limit as in the general setting I set a limit of 5000
### Author: ![chapoi](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/chapoi/32/537252_2.png) [@chapoi](https://meta.discourse.org/u/chapoi)
#### Post date: [12 juni 2026 om 10:44 UTC](https://meta.discourse.org/t/how-to-change-invite-limits-for-everybody/405150/2 "2026-06-12T10:44:20Z")
</div>
Which setting have you changed? And how are they sending invites?
The top one should suffice if your users are sending individual invites.
 ![CleanShot 2026-06-12 at 12.37.14@2x](https://global.discourse-cdn.com/meta/original/4X/1/0/3/103550df061655903c1e0603cebd137cc71c26f7.png)
But I think you’ll need to change the bottom one too, if you want them to be able to send re-useable invite links.
Can you try that?
