How to Customize one category view
(Fred Vom Jupiter) #1
Hello together,
i’m looking for, how to change a view for only one category.
For the category “Stories und Projekte” i just want to show the thema, likes and the antworten.
how can i customize this.
Thanks for your help.
:slight_smile:
(Fred Vom Jupiter) #2
I found it by adding this to the Custom CSS to delete the posts… and so on
.category-stories-und-projekte .topic-list .posts {
    display: none;
I’m not sure that this is the best way to do it by it works.
Now how to put the “likes” column before the “Topic” column like he did
