How to delete unused images?
(Sat) #1
I do see user upload many versions of same image and they are not used…so how to delete those unused images?
This will also help to reduce backup size.
(Stephen) #2
Images which aren’t attached to posts do get periodically deleted after they age out.
If you’re worried about backup sizes consider using a CDN such as S3 for assets, and only back up the database. A backup with uploads option exists too, enabling it will only back up your data, but I wouldn’t do that unless you know your assets are safely offloaded elsewhere.
(Sat) #3
Thats great! good to know that is taken care by system. thanks!
