How to disable onebox and perhaps add a custom class to a link?
(Shri) #1
Is there any way in which I can disable onebox-ing of links in posts?
I notice it has been requested here - Disable onebox for specific links but no solution was offered.
Also, I assume if I wanted a specific class inserted into every link (a href class=“whatever”) within a post, I’d have to write a plugin?
(Shri) #5
Ok, commenting out this line seems to be the most reliable hack, to get rid of onebox.
lib/oneboxer.rb - comment out calls to onebox_raw
Done through app.yaml
  after_code:
    - exec:
        cd: $home/lib
        cmd:
          - sed -i -e 's/    onebox_raw/##shri    onebox_raw/g' oneboxer.rb
Seems to survive rebuilds / posts:refresh_oneboxes etc
(Jeff Atwood) #6
Just put a space or any character in front of the link. Oneboxing only works for links on a line by itself.
(Shri) #7
Jeff - Tried that from a suggestion on another post. Works well for inline links but for some reason our users are trained from another forum software to just insert the link on a standalone line and have embedly do the rest.
Pretty much everyone helping test my dev sites ignored that. Not very instinctive.
Apologies in advance if this mucks up someone’s installation. :slight_smile:
A lot of this for me is grepping through the code and figuring out how it works. My ruby skills are limited to commenting out code at the moment. :slight_smile:
This is what I ended up with:
https://newsfora.com/t/onebox-disabled-through-app-sed/19
