How to disable or visible false top menu category dropdown dynamically
How to disable or visible false top menu category drop down dynamically.
I don’t understand what you’re asking. What do you want to disable? I don’t know what “top menu category drop down” refers to. In your image there is a dropdown menu deals > and a Top link. Which do you want to disable or make visible? What are the conditions that will make it disabled (do you mean hidden?) vs visible? Do you want the Top to not display if there are no topics in Top?
Top menu means Deals Drop down, Latest , New(1) Top…
Hear i need to show only Deals category posts… i have filtered with category , it is working fine…
i need to disable the category selection…
.categories-list ol.category-breadcrumb {
display: none;
